How to set audio processor for DVK/DAX?
Andy - KU7T
Andy - KU7T Member ✭✭
edited January 2020 in FLEX-6000 Signature Series
I know how to use the processor, mic gain and EQ for the MIC or BAL inputs. I use low power and listen on a dummy load and hear the difference when changing settings. But, I do not seem to be able to adjust the same for the DAX stream of recorded messages. TX gain is the only one. How to adjust compression for DAX? Andy KU7T
  • Bill English
    Bill English Member
    edited January 2020
    I noticed the same thing Andy.
    I think the only option would be to process the audio when you record it. All I see is the TX level in the DAX app controls.
    Bill K4FX
  • Andy - KU7T
    edited March 2019
    Is this what others are doing? Process in Audicity? Andy KU7T
  • Johan _ SE3X
    Johan _ SE3X Member ✭✭
    edited March 2019
    Yes, at least I do. Found it to be the best way of getting good audio out. Using N1MM and Audicity recorded files.
    Always trying to adjust audio having my recordings sound as loud as when using the mic. Really dislike when answering someones recording and having a totaly different audio level coming back to me and/or even worse, a different voice. Only creating confusion and thoughts like "are there another station on the same QRG?" Who's answering me?
  • Andy - KU7T
    edited March 2019
    I played with this this morning. It appears that I was wrong. Processor and EQ is applied to the DAX TX stream as well. My main issue was I was running with too much gain and it sounded terrible. Now with tips being green and yellow but never red, all is good. Andy KU7T
