Ham Radio Deluxe v6.5.0.196
edited December 2019 in FLEX-6000 Signature Series
Before installing the update...has anyone had any issues with the newest HRD release
Welcome!
  • Member
    edited July 2019
    Absolutely no issues at all. It worked just fine. It was a seamless update. I use the log, rotor and cluster. It worked 100%
    Neil   N4FN
  • Member
    edited February 2019
    No issues at all!!
  • Member
    The only issue I have found so far , is a problem in the LogBook Awards section.
    The DXCC Digital calculation is incorrect.   Mike is already aware of it, and will get it fixed in the next update.
  • Member ✭✭
    It does take some time and needs to installed a microsoft program before installing HRD and then needs to restart you computer etc. Saying this I have installed on 2 win10 machines but have not ran HRD since. It did not mess with my DAX or CAT as I have ran other software which is OK
  • Member ✭✭✭
    HRD 6.5.0.196 had issues with password persistence and has been updated to 199:
    HRD 6.5.0.199 running here without any problems
    https://www.hamradiodeluxe.com/downloads.html
  • Member ✭✭
    edited March 2019
    This version v6.5.0.199 is great and one of the best so far for Flex radios that I have use.
    However; HRD needs to do more for those of use using Flex gear.
    I wrote HRD after the installation and inquire; why there so many updates for the oversea radios.
    This is their replied:
    Kevin (KC7FPF) posted 02/27/2019 11:58 AM
    Good morning Ernest:
    Thank-you for contacting HRD support. One of the goals with HRD to allow the flex radio to interface the HRD a bit better The development is looking at it. Hopefully some time soon.
    If you use HRD, send then a complement for this upgrade and let them know you are waiting for their updates to include a **** here and there for Flex users.
  • Member ✭✭
    edited May 2019
    My install went perfectly no problems at all.
    de Roger W6VZV
