Burning 6400M!
Dave, I would open a ticket with Flex immediately. I’m sure they will sort it out quickly for you. Winston1
I found the support portal. Flex seems like a great company. Im sure they will help me out.0
Dave Hope your not using the Internal Antenna Tuner And the External Antenna Tuner at the same tine This can stress the Filter Networks and possibly Damage them Only use One Tuner If your 6400M has no internal tuner then I am not sure what the issue is 73 Mike0
The two tuner issue has been discussed before. There is no problem if done correctly. Tune external with radio in bypass. If match not achieved then tune internal to bring into match. I suspect Dave has only external tuner. 73 Bob W5TX0
My Flex does not have the internal ATU. Was using external Palstar AT-Auto
All I have to say is Flex is amazing. They are sending me a new radio! I do want to make sure nothing environmental could have an impact on this. Does anyone use any isolation devices, ferrites..etc Just want to protect the radio anyway I can. I have used many radios in this shack even with an amplifier and have never had an issue.
Dave,
I have nothing but praise for Flex Radio. I am, also, using my 6600 with the Palstar HF-Auto tune, along with the Palstar LA-1K amplifier or the Ameritron 600S, and have not encountered any problems. With the HF-Auto tuner, I never need to engage the internal ATU.
I do use ferrites on most of my connecting cables inside the shack, plus I have a 1:1 balun at the antenna feed point on all my antennas. I use mix 31 for the ferrites.
Let us know when you get the new radio on the air.
Awesome! I will! I think im going to put Ferrites on everything just as a a good measure.
Get a few of the FT-240-31 Ferrite Cores for RFI suppression These cost about $12 each These I loop 4 to 5 turns of the CAT Ethernet Cables thru them to keep RF out of them Also loop multiple turns of my RF and Audio Cables thru them Search EBay and Google Search for them Best investment to protect your equipment 73 Mike1
Get these FT240-31 RFI mix 31 cores 73 Mike https://www.jpmsupply.com/Toroid-Core-FT240-31-Ferrite-p/38022.htm?gclid=Cj0KCQiA5NPjBRDDARIsAM9X1GKtgXLIa5ytIcHzH5JYNulUqGCM-U2RXFIBgAui05-mxDaQFmA71pcaAskaEALw_wcB&click=21
Do you usually place your cores near the port of the radio / swtich... or both?
Dave:
I have ferrites on just about every interface cable to the Flex and had them on the Elecraft radios that I replaced.. I was having some RFI issues due the fact that I bring balanced feeders right into the shack and tune them with old E F Johnson match boxes.
There are a series of articles written by K9YC and W1HIS about common mode chokes. They are archived on the internet. The cores that they use are available from DX engineering, Pro Audio, and Mouser. Mouser has the lowest prices, however, you must know the correct "Fair-rite Part number if ordering from them ( the articles have the part numbers mentioned). I use the larger clamp on cores with multiple turns through them rather than several smaller cores (its the square of turns ratio). I also have cores on the HDMI cables ( both ends) and either net cables. I also use the 2.4 inch mix 31 cores if the cable ends will go through. I keep a few extra cores on hand just in case.
Gayle K0FLY0 -
Yes nearest the radio and nearest to Amp (Both Sides) 73 Mike0
STOP!!
By the time you spend lots of $$ on cores and clamps plus shipping and then spend days or weeks of reading, posting and learning how to wind them properly you can simply install these bads boys and call it a day ! They are a bargain at $49 a pair. Better yet buy the 10 pack and get free shipping. If you dont need 10 then split the cost with a friend. I am not a DXE spokesperson or affiliated with DXE in any way.
DX Engineering ISO-PLUS Ethernet RF Filters
https://www.dxengineering.com/search/product-line/dx-engineering-iso-plus-ethernet-rf-filters?autovi...
PS - Yes, I have spent lots of $$ and countless hours learning and intsalling chokes and clamps on every wire and cable in my shack and it really helped my station perform better. Just trying to make it easy for you. However, if you want to learn a new skill then you have some good advice in this thread. Also, take a look at HamNation #386 and #390. See how the master himself does it !
Your assuming RF gets only thru Ethernet cable but It can travel down other lines, Coax Lines, Power Supply Audio cables, radiation back into Shack, etc Any cables attached to Rig can allow RF into Rig To damage it RF can travel down Coax Lines and get back into Rig 73 Mike0
You are absolutely right ! I was only suggesting an easy way to place chokes on ethernet cables. But every wire and cable in the shack and beyond needs to be addressed. It's quite an effort to do it correctly !0 -
Joe, have you had any experience with the DX engineering devices? Seems like they use a different technology to filter or isolate. Would you need to buy these for every device? Thanks so much for the suggestion. I am just trying to do everything I can to make sure the Flex is protected. I do not know if external environmental variables had anything to do with it, but I want to make sure I am doing the best I can to prevent anything from happening.
I agree Flex has great customer service, im sure they wont please everyone, and nobody can, but im a happy camper!0
No, not with these new Ethernet chokes. However, I do have some of their gear and it is top notch. Tim Duffy (K3LR) really knows his stuff when it comes to building a world class station and preventing RFI and damage to equipment. Give them a call and talk to them about your situation. Operators are standing by !0
I did talk to them. I got the 10 pack. Again I’m not sure my environment had anything to do with the failure I just want to do the best I can to insure a proper environment for the Flex.0
Hi Dave,
Here are a few links to my Flex 6700 web page that may be of interest. The links are to notes on RFI, grounding, lightning protection, Ethernet and USB protection I've employed on my 6700.
RFI and Grounding
http://www.nn4zz.com/FLEX6700.htm#RF_issues_and_solutions
Ethernet protection for both power surges and RFI
http://www.nn4zz.com/FLEX6700.htm#Ethernet_Lightning_Protection
USB port protection for both power surges and RFI
http://www.nn4zz.com/FLEX6700.htm#USB_Port_protection_
And other notes, links, etc
Al / NN4ZZ
al (at) nn4zz (dot) com
6700 & SSDR-W V 2.4.9
Win10
Just because you think the smell was "strongest" near the ethernet port doesn't mean you should spend $hundreds on a bunch of over-priced filters. If RF burned up your ethernet port, it is all but certain that the port would no longer link-up. So I don't think that is what happened.
Most likely, a manufacturing defect is causing a failure in the PA, or a 1/10000 part failure occurred in a benign spot. Low-voltage tantalum caps used for power supply bypass have a tendency to fail and when they do - it's like a roman candle going off.0 -
I agree, I strongly believe this could have been a fluke. What was strange to me is the port itself had the strong smell of burning pcb which is far away from the PA section. Im really doing this in the spirit of good practice. If for any reason this where to happen again, I can prove to Flex I am doing everything I can on my end to maintain a good operating environment.0
Wow Great stuff! Just curious why you did not go fiber to the Flex.
Hi Dave,
RE: "...why you did not go fiber to the Flex."
The fiber link to the switch provides isolation from the long ethernet cables throughout the house and from the server room. Any power surges, RFI or lightning induced surges would be stopped at the fiber link and before they get to the switch.
The switch is located just inches away from the Flex 6700 and the shack PC. So by using a switch I get protection for the radio, PC and anything else I may connect to the switch. The cat5 jumper from the switch to the radio is very short ( about 18 inches) but I also have ferrites on it to suppress any RF that may be in the shack. (Probably not needed but suspenders and a belt).
Al / NN4ZZ
Win10
So today I got my replacement 6400M. Everything is flawless so far! Flex support is amazing!1
Hi,
i have a similar issue using the Flex6400M on 10m in FM. After a while it begins to smell as something would burning. Turned the output down from 100W to 50W already and will check the temperature via FrStack next. Strange. In SSB i had no problems so far. Radio is since 10/21 in use without any problems. I think i will open a ticket.
73‘, Stefan
FM uses 100% RF Power. SSB uses less than 1/2 of that. FM will heat up the finals. If you are having long QSO's I would highly recommend you drop your power to 50%. That is only a 1/2 S unit difference for the person at the other end who is receiving you. But it produces much less heat in the radio.
But, yes, keep an eye on the temperature. Also, if you have dust in the radio, it will smell when things get hot.
Well, it smells! So obviously things are getting hot already. The only question for me is: „Is that a problem that could cause in a damage?“ If dust comes out of the radio, it might be to late? It‘s hard to see whats going on in the radio. I‘ll do some further tests in FM, even it‘s my favorite mode;-) Longer Qso‘s in FDV were never a problem, even with max RF Power. Maybe it‘s like you setup a toaster the first time: it smells🤔
Did Flex happen to mention what was wrong with the first radio? I'm at least the 3rd owner of a very old 6500 and would not have the luck of a replacement. 😅 We'll see how my ticket goes.
- 325 Community Topics
- 590 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 394 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9.1K Radios and Accessories
- 14 Aurora
- 152 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 867 Genius Products
- 445 Power Genius XL Amplifier
- 308 Tuner Genius XL
- 114 Antenna Genius
- 274 Shack Infrastructure
- 194 Networking
- 135 Contesting
- 717 Peripherals & Station Integration
- 135 Amateur Radio Interests
- 939 Third-Party Software
