Flexlogger WSJT monitor stations?
N8FNR
I have Flexlogger talking to SSDR and my 6400 OK. However I can't figure out how to get WSJT stations to display in the Stations tab. I have Monitor WSJT enabled in the Settings tab but it does not seem to do anything. How can I get stations to display?
Zack
N8FNR
Zack
N8FNR
Hi Zack,
Do you have the UDP broadcast enabled in WSJT-X? You need to enable this and ensure that the port number matches the port number setup in FlexLogger on the configuration page.
Mark1 -
I did have UDP enabled in WSJT. Where do I enter it in Radio Definition?0
Program configuration, Online & Lookup. There is a spot to put in the port number. This needs to match the port set in WSJT-X.
Once they both match, on the WSJT panel, disable monitoring, then re-enable it.
And... read the text there. Currently if you are using JTAlert there is a fight for the UDP data that is not resolved. The first program to connect will get all of the data. I am looking into ways around that.0 -
I must be missing something. I am running the latest version but cannot find program configuration.
It is the small gear icon at the far left0
Ohhhhh! Dun. Thanks!
Zack0
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
