Flexlogger WSJT monitor stations?
N8FNR
N8FNR ✭✭
I have Flexlogger talking to SSDR and my 6400 OK. However I can't figure out how to get WSJT stations to display in the Stations tab. I have Monitor WSJT enabled in the Settings tab but it does not seem to do anything. How can I get stations to display?
Zack
N8FNR
  • Mark WS7M
    Mark WS7M ✭✭
    Hi Zack,
    Do you have the UDP broadcast enabled in WSJT-X?   You need to enable this and ensure that the port number matches the port number setup in FlexLogger on the configuration page.
    Mark
  • N8FNR
    N8FNR ✭✭
    edited February 2019
    I did have UDP enabled in WSJT. Where do I enter it in Radio Definition?
  • Mark_WS7M
    Mark_WS7M ✭✭✭
    Program configuration, Online & Lookup.   There is a spot to put in the port number.  This needs to match the port set in WSJT-X.
    Once they both match, on the WSJT panel, disable monitoring, then re-enable it.
    And... read the text there.  Currently if you are using JTAlert there is a fight for the UDP data that is not resolved.  The first program to connect will get all of the data.  I am looking into ways around that.
  • N8FNR
    N8FNR ✭✭
    I must be missing something. I am running the latest version but cannot find program configuration.image
  • Mark_WS7M
    Mark_WS7M ✭✭✭
    It is the small gear icon at the far left
  • N8FNR
    N8FNR ✭✭
    Ohhhhh! Dun. Thanks!
    Zack
