DX Labs SpotCollector to Flex 6400/Maestro - FT8
Joseph Hill
When I double click on an FT8 spot in DX Labs SpotCollector, the Flex 6400/Maestro uses USB instead of DIGU. Any ideas why this would be happening?Thanks!
Joe/K4PX
Joe/K4PX
When you double click on a spot...In Commander...does the Mode: Indicate DIGU...and is DIGU selected (lower right side of the box)
Regards
Ronnie0 -
Ronnie...not sure what Commander is? Joe0
Commander is a part of the DXLab Suite....you may want to check with the DXLab user group but I believe you will need to run Commander when you are using Spot Collector.
I checked my setup...I use DXLab, WSJT-X and JTAlert...my FT8 setup is working as it should.0 -
I do run Commander like you Ronnie. But the spots are in SpotCollector not in Commander. Thank you. Joe0
I realize that the spots are in Spot Collector...but when you click on a spot...Commander determines radio mode...I believe I have that correct...but again I would refer you to the DXLab user group for more detail.
Regards
Ronnie0 -
Ok thanks much Ronnie. Joe0
Make sure SpotCollector is configured like this. This is what tells the radio to use DIGIU for FT8.
Thanks Joe!0
Yes, you must run commander0
Yes0
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 950 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
