RF Pwr scale 'freezes' during tx
Russ Locke
The screen shows a tx issue with the scale freezing but the signal going out just fine. So it appears it is a software issue. Anyone have any similar issues? Rig is a 6300 into a TransWorld 1020 antenna.
Russ, K5FJR
Russ, K5FJR
I can tell you it is not a software issue, perhaps a factory reset?0
How close is the antenna to the rig and computer?
Bob, WK2Y0 -
I had the same problem with both TX and RX. It was suggested to me that I remove the ethernet cables and put them back in. I did and the problem went away. Very easy thing to try.
Pat Eastman
K7PWE
This morning I checked into a 20m net and the display showed no output at all but my signal was fine. The slice flag shows reception as does the waterfall and other indicators. I'm going to try K7PWE's suggestion and remove and reattach the Cat 5. Also, fwiw, this all started when I removed my coax to clean the connections. I've gone back and checked those connections and all seems fine.
I've tried a number of things and nothing has worked. I've noticed now that it is a 'pulse' affect: every 5 seconds or so the display freezes for a second or so. No degradation in TX or RX but visible in the waterfall and all other display functions.
You must have done a factory reset as it was suggested to you. If the display is effected it sounds like a connection problem, a data problem. Make sure you are directly connected to the computer from the radio, and try different ethernet cables.0
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 178 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
