SDR Voice Keyer for Mac Version 2 Released
Pete - W6OP
I have released version 2 of my SDR Voice Keyer for the Mac today.
https://w6op.com
Version 2 has a slightly different layout and the larger buttons will allow you to label each one. There is also an ID timer that will light an indicator when the time has expired and has a dedicated button and audio file for sending your ID.
Peter W6OP
https://w6op.com
Peter W6OP
2
Awesome Job !! This is Great, making up some recordings now so I can put this to good use !0
hi pete
nice app...
i did notice if 'no radio" is available to select the 'select radio' panel does not go away
and
then unable to get back to main vxkeyer control panel...
only way out is to quit and restart the app.
Also the manual is a .pages format..and that is fine ok for most mac user BUT a .pdf version would be nice
nonetheless...still a nice and needed app
keep of the great work
right now, i am in the process of creating some voice files to test it with my 6600M
Paul K3SF
Thanks! I'll fix that shortly.
I can do a pdf file instead of pages. The same info is also on the web page.
Pete W6OP0 -
hi pete
tried it on the following setup
Mac min-i7 running highsierra 10.13.6
and
Flex 6600m running ssdr (2.4.9) native on its main display
DAX is selected on p/cw panel on 6600m (sri no pics)
created .wav files using audacity
and
linked the wav files to sdrvoicekeyer via preference panel
as you can see...voicekeyer does seem to connect to the 6600M
as it show the TX slice and mode and freq and shows it is connected
as you can see it connected to the radio...
but
when i click on any of the buttons of voicekeyer
nothing seems to happen
radio does not go into transmit and no modulation via DAX
would be glad to work offline with you to resolve this
Paul K3SF
Send me an email at (support at mycall dot com) and I’ll see what’s going on. Pete W6OP0
Paul, did you make sure to set the rate at 24000 on the recorded files ? I didnt do that first time and they wont work.0
Yes, 24khz or a multiple such as 48 or 96. Though I should show an error if it isn’t. Paul, send me one of your files too. Thanks, Pete W6OP0
hi pete
sent you an initial email
will get the .wav to you shortly
Paul K3SF
hi pete
well after all your help offline .... I T W O R K S
i had to cleanup my .wav files...that was the key
MONO mode..... NOT stereo...
and
24000 sample rate
i now have it running nicely with a Mac Mini i7 with macos 10.13.6
and
flex 6600M
Pete deserves an "Atta-BoY" from me....
Nice all around...
Paul K3SF
I had a feeling it was a wave file issue. I found that out trial and error, then reading the setup instructions lol ..1
The next version will support stereo files. Also, if anyone has the buttons changing size with long labels that will be fixed too.0
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
