SDR Voice Keyer for Mac Version 2 Released
Pete - W6OP
Pete - W6OP Member ✭✭
edited March 2020 in New Ideas
I have released version 2 of my SDR Voice Keyer for the Mac today.
https://w6op.com
Version 2 has a slightly different layout and the larger buttons will allow you to label each one. There is also an ID timer that will light an indicator when the time has expired and has a dedicated button and audio file for sending your ID.
Peter W6OP
2 votes
In Review · Last Updated
  • W1MSG
    W1MSG Member ✭✭
    edited February 2019
    Awesome Job !! This is Great, making up some recordings now so I can put this to good use !
  • K3SF
    K3SF Member ✭✭✭
    edited March 2020
    hi pete
    nice app...
    i did notice if 'no radio" is available to select the 'select radio' panel does not go away
    and
    then unable to get back to main vxkeyer control panel...
    only way out is to quit and restart the app.
    Also the manual is a .pages format..and that is fine ok for most mac user BUT a .pdf version would be nice
    nonetheless...still a nice and needed app
    keep of the great work
    right now, i am in the process of creating some voice files to test it with my 6600M
    Paul K3SF
  • Pete - W6OP
    Thanks! I'll fix that shortly.
    I can do a pdf file instead of pages. The same info is also on the web page.
    Pete W6OP
  • K3SF
    K3SF Member ✭✭✭
    hi pete
    tried it on the following setup
    Mac min-i7 running highsierra 10.13.6
    and
    Flex 6600m running ssdr (2.4.9) native on its main display
    DAX is selected on p/cw panel on 6600m (sri no pics)
    created .wav files using audacity
    and
    linked the wav files to sdrvoicekeyer via preference panel
    as you can see...voicekeyer does seem to connect to the 6600M
    as it show the TX slice and mode and freq and shows it is connected
    as you can see it connected to the radio...
    but
    when i click on any of the buttons of voicekeyer
    nothing seems to happen
    radio does not go into transmit and no modulation via DAX
    would be glad to work offline with you to resolve this
    Paul K3SF
  • Pete - W6OP
    Send me an email at (support at mycall dot com) and I’ll see what’s going on. Pete W6OP
  • W1MSG
    W1MSG Member ✭✭
    Paul, did you make sure to set the rate at 24000 on the recorded files ? I didnt do that first time and they wont work.
  • Pete - W6OP
    Yes, 24khz or a multiple such as 48 or 96. Though I should show an error if it isn’t. Paul, send me one of your files too. Thanks, Pete W6OP
  • K3SF
    K3SF Member ✭✭✭
    hi pete
    sent you an initial email
    will get the .wav to you shortly
    Paul K3SF
  • K3SF
    K3SF Member ✭✭✭
    hi pete
    well after all your help offline .... I T   W O R K S
    i had to cleanup my .wav files...that was the key
    MONO mode..... NOT stereo...
    and
    24000 sample rate
    i now have it running nicely with a Mac Mini i7 with macos 10.13.6
    and
    flex 6600M
    Pete deserves an "Atta-BoY" from me....
    Nice all around...
    Paul K3SF
  • W1MSG
    W1MSG Member ✭✭
    I had a feeling it was a wave file issue. I found that out trial and error, then reading the setup instructions lol ..
  • Pete - W6OP
    The next version will support stereo files. Also, if anyone has the buttons changing size with long labels that will be fixed too.
