DDutil and Smarlink - Says Connected But Is Not
jerry stern
How can I get DDutil v3 to work with SSDR and 6700 under Smartlink?
My new Asus laptop does not have an ethernet so I am running Smartlink in same home network as my 6700 is hardwired. I start DDutil 3.2.0.7.5 and I get a popup that says DDutil connected to CAT Server but nothing appears connected and in the setup form under Radio I have Signature but no specific radio appears in the list box. When I close DDutil I get a popup that DDUTIL has disconnected from CAT Server. My SSDR CAT shows only 2 things - Serial Com for Slice A and and second is TCP: Port 5002 Slice A.
I got the same thing (Serial Com for Slice A and TCP Port 5002) today. I think windows did an upgrade (mine didn't install and showed an "install error-try again" And I'm struggling to re-configure all the CAT ports as before. I believe those are the default ports for the flex startup (I have a 6600M)0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 94 Aurora
- 988 Maestro
- 963 Genius Products
- 353 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
