DDutil and Smarlink - Says Connected But Is Not
jerry stern
jerry stern Member ✭✭
edited February 2019 in SmartSDR for Windows
How can I get DDutil v3 to work with SSDR and 6700 under Smartlink?
My new Asus laptop does not have an ethernet so I am running Smartlink in same home network as my 6700 is hardwired.  I start DDutil 3.2.0.7.5 and I get a popup that says DDutil connected to CAT Server but nothing appears connected and in the setup form under Radio I have Signature but no specific radio appears in the list box.  When I close DDutil I get a popup that DDUTIL has disconnected from CAT Server.  My SSDR CAT shows only 2 things - Serial Com for Slice A and and second is TCP: Port 5002 Slice A.
  • W5AP
    W5AP Member
    I got the same thing (Serial Com for Slice A and TCP Port 5002) today. I think windows did an upgrade (mine didn't install and showed an "install error-try again"   And I'm struggling to re-configure all the CAT ports as before. I believe those are the default ports for the flex startup (I have a 6600M)
