For the 3x time I set up TNFs on 6 m using rember button & then updated a global profile. Freakn' di
Ray Kenny
For the 3x time I set up TNFs on 6 meters using rember button & then updated a global profile assuming they would be saved. No, they freakn' dissappeared again. So, how do I save my TNFs?
In the TNF selection box are you selecting ,,remember TNF?0
Yes0
Just for grins I did the same thing here, only on an 80 mtr frequency. Made three tnf's within the panadaptor view, clicked on "Remember", got the green indicator for each tnf, saved a global profile. closed, then re-opened SSDR 2.4.9, and when it came up they were not there, so I re-loaded the saved global profile, and they didn't come back then either. Now, that said, if you leave them on when you shut down SSDR without deleting them, they will stay, like they're supposed to.Now, if one can make the persistence of remembering the tnf Stick in the Global profile would be a plus, then, if you delete them but at some point you want them back, re-load the global profile to get them back.
Thanks Jim, I’ll give that a try nxt time so I hopefully do not unleash more choice #$*@!, ? ‘s. - Ray1
Sorry Jim, tried your suggestions with no luck. Lost all 6 m TNFs again. On my 6400M, I conclude that there is no method to save TNFs. It would be nice to have a numerical keyboard option to enter TNF cntr freqs & widths. ‘bye, Ray0
You have stumbled upon the primary reason why I never use Vox hihihi.
so you are telling me that when yuou set a tnf, and turn it green, shut down the radio and bring it up, it doesn't bring the tnf's back up?..that is a bug I believe. Perhaps a help ticket is in order if you haven't already.
Interesting, I set my TNF on all bands for band markers. they have never dissappeared, ever. But one time they did when I chose remove all TNF.0
Bill, at what must be another attempt in self-flagellation, I set a 6m TNF for my 6m tx/rx slice and it will not save worth jax. Making me wonder abt holes in software for 6400M. 'bye, Ray0
Slice B0
It may be only a 6400M thing, Lets see what Flex thinks as they check this out.0
If this is not working for you, then please open a support case so we can track it correctly.
thanks0 -
Michael, I submitted a support tix. Tim said they consider this issue is most likely to be a software related issue. It was transferred to the software support grp with no est. as for time for further analysis or resolution. Thanks, Ray KC0IBO0
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
