Maestro Screen Orientation
Doug - W3UB
I was away for three months, and when I returned the Maestro had booted up due to a power outage, and the screen orientation was sideways.
Looked at some old posts, did a "reset" by holding down the power button until it was off including the button LEDs. Then removed power for a minute or so. Then applied power and it booted up fine.
But, every time that I turn it on now, it reverts to a sideways orientation ... Not good.
Am I missing something obvious?
/Doug
/Doug
We are investigating a software fix for this that should prevent the screen from changing orientation by 90 degrees. The preliminary results are very encouraging. However, it looks like that it may be in the June timeframe before it will be available in SmartSDR v2.3.
In the meantime, we have found a workaround. If you do a forced shutdown of the Maestro, which is to press and hold the power button until the blue "shade" appears with the instructions to slide it down to shut down, continue holding the power button until the Maestro turns off. Then do the power cycle (remove power from the unit) before starting up again and it should boot up in the correct screen orientation. You will have to shut down this way until we can push out the software fix.
3 -
I have experienced the same issue and am wondering about the status of a software fix?
Jeff, W5QR
This problem has been fixed.0
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 306 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
