Does smart sdr need to be running for bcd on virtual port?
Jamie WW3S
Jamie WW3S Member ✭✭
edited February 2020 in FLEX-6000 Signature Series
Will the bcd data on the USB ports be available without running smart sdr
  • Rick N4RZ
    Rick N4RZ Member ✭✭✭
    The USB ports will work and supply the necessary data whenever the radio is being operated.  It can be operated from SmartSDR, The M model front panel, Maestro or from an IOS device.
    edited April 2019
    To back up what Rick says, it does what you wish now.   This is the cool features of the Flex 6000 radio series and that is that the radio supports multiple clients at the same time.  I consider clients, logging programs, digital programs, amplifiers, band devices, steppirs, etc.
    Other HF hardware available today is designed to support a single device or program.  Icom's CI-V was to be able to handle multiple devices with the CI-V bus, but I don't know many who actually did it and got it running well.
    As well as being an amazing RF deck, the Flex was built from the ground up to be your Radio Server sharing band data, audio streams, transmitter, etc.
    Jamie, have you wired it up yet?
  • Jamie WW3S
    edited April 2019
    Good morning Mike...by wired up, do you mean the USB cable? IF so, no, not yet....baby steps here, doing a complete shack makeover, new pc on Windoze 10.....I have have the new Flex running on rx, and have received some rtty with it, next step TX I suppose, going slow as to make sure I get it right the first time...
    edited February 2019
    Good
    Make sure you review Section 28 in the SmartSDR users manual.
    It goes over most things.
