Heil 781 for Maestro...cable?
Joseph Hill
I want to order a Heil 781 to use with my Maestro/6400. Anybody know the correct cable I will need? There are lots of choices and the dealers are giving me inconsistent answers. I am planning on getting the Heil boom and Heil shock mount too. Thanks.
Joe
Joe
To use the PR781 Mic with a Maestro, you would likely need the Heil CC-1-XLR-YM. It's a Modular 8-pin adapter with Yaesu Pinout to XLR Plug. I'm not sure what would be needed with the 6400. I would call Heil Sound and ask them. THey are very helpful. 73, Dave, K1DLM1
Thanks David.0
let me ask you guys a further question so the cable that goes from the Heil 781 to the maestro is a different cable that goes from the Heil 781 to the flex 6400 so for a base station microphone on a boom and I am I better off plugging the microphone into the Maestro or into the 6400 add another question is as a maestro user can I plug the microphone into the 6400 if I'm always using the maestro0
My Shure 55 is plugged into my 6500 balanced jack, and I am using the Maestro with no issues. Not sure what the 6600 uses, but there are adapters to use it on multiple connectors.
Gene, K1GD0 -
Yes, they are different.
If the radio is nearby, I would plug it in the radio and not the Maestro.
Yes, you can select a Mic plugged into the radio while using the Maestro.0 -
Thanks Michael0
Thanks Maher0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
