Was the DDUtil Power Drive Feature Added to SDR Ver 3
Reggie
Was SDR Ver 3 updated with the DDUtil functionality to set the drive power per band when using an amp?
Reggie
N3OP
That would be telling......0
You can do that now if you're using an SPE Expert Amp. I'm not sure about any other amps doing it. I got it working here after reading the forum post by N2RJ:
Ria - N2RJ, Elmer
- 2276 Posts
- 914 Reply Likes
You can use DDUtil, that is one option.
You can also use the USB cables and have the amp control drive power. I prefer this method because it supports the two inputs for SO2R. DDUtil will only send band data for the current transmit slice so you're really limited to only one output from the radio. I don't know if this has changed but last I checked this is how it was.
Basically you get an FTDI adapter or make a 9 pin to 15 pin cable according to the SPE manual. Get two if you're using the two inputs.
Use only the Relay line. Do not use ALC.
Configure your USB ports to CAT mode, and set it to follow the antenna port.
Then set the amp to FLEX mode.
Adjust drive power using the arrow keys on the front of the amp. You must set it once per band and once per power level (Mid/Max/Low). The front of the amp will display "PC=XX" which is the drive power level. Adjust using a dummy load to set desired power. I believe 1500w for Max, 1kw for Mid, and 500W for low. This is a one time thing. When you change bands, the amp will automatically set power in SmartSDR.
HTH0 -
DDUtil does not currently support SSDR v3. This is currently in-work.0
I use it that way all the time with my SPE 1KA Amp with no issues Ian0
Is anyone doing this with the Elecraft KPA500 amp?
Reggie0 -
I have a close friend with a KPA1500 connected to his 6500 with a lan cable only. It talks to the amp and everything is controled from the Flex,,it works perfect. No DDUtil0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
