Lack of Diversity setting persistence on 40m
Hi, I'm a new Flex user and have a 6600 and Maestro hardwired together. Antenna A is a myAntennas HF8010 and Antenna B is a Cushcraft R7. I have set up diversity reception for 80, 40, 30 and 20 meters. I can switch back and forth between any combination of 80, 30 & 20 and all the settings are remembered/persist. However when in 40m with diversity set, if I switch to 80, 30, or 20 and then back the 40, it goes back to Rcv on A (transmit is on A) and forgets that it was previously set for diversity. Anyone else observe this? Or am I overlooking something?
Ken
Ken
Read about transmit profiles in the manual. You need to save a transmit profile. 73, Mack W4AX Alpha Team0
Thank you for your response. I re-read the manual sections on profiles. I am using the SO2RDefault Global Profile and three TX Profiles: 80M CW, 20M - 40M CW and 10M - 17M CW which are basically the same, but 10M - 17M CW has 8db gain added. All are set for CW 400 NB NR APF QSK AGC-M DIV. The MIC profile associated w SO2RDefault is Default.
This is my default operating configuration, one Panafall, one Slice. Sometimes I'll turn on SL B to work a DX station split, but then I'll put it back to default.
The Maestro manual section 14.7 implies that Persistence and Profiles are independent, although I can imagine that there might be some undocumented Persistence dependence upon the state or configuration of one's profiles, so I double-checked mine.
I move back and forth between 80, 40, 30 & 20 and have the SO2RDefault : 20M-40M CW : Default Mic profiles engaged. Here's is what I observe happens WRT persistence in order of frequency:
1) DIV is turned off after moving to a new band
2) If DIV is not turned off, often Tab A is panned R (so both Tab A and Tab A Div on on the R ear)
3) DIV off as well as NB, NR, APF all off, but the sliders for NB, NR & APF are remembered
4) SL B is activated and comes up on 14.150 USB 2.7k, this happens on any SL A band
5) SL B appears 14.150 USB 2.7k in a second Panafall
I've also noted that my RX equalizations have been zeroed, although I don't know when.
All the dial-associated settings seem to persist (e.g. AGC-T, filter mode & settings, everything on the TX menu.)
BTW, I had a separate thread on the ATU / QSK conflict and I am favoring using the ATU in preference to QSK. However I am note that the QSK does not always vanish, sometimes I can have both.
This is just an annoyance for me, half a dozen button pushes after band switching and I'm back in business. I'm not a contester. More importantly, I'd like to know if others observe this same behavior or whether there is something wrong with my brand new Maestro / 6600 or my configuration of them?
On this last point, I have also heard Radio-originated popping in the headphones periodically and have assumed that was a software implementation artifact to be ignored. Do others hear these?
Configuration-wise my 6600, Maestro & Macbook Pro all have short EN cables to a gigabit switch which has a 30' EN cable to the router. I am on the second floor. A 1ft #10 copper ground wire connects the power supply to the 6600 and a 15ft #10 copper ground wire to the mast of my vertical which has a 12ft ¾" strap to earth ground. Not ideal. I will be installing common mode chokes on all lines this weekend. Currently only ANT1, the HWEF-8010, has a CM choke which dropped the noise floor 4db.
Thanks in advance for insights,
Ken WC6Y0 -
Maybe I'm doing something really boneheaded. I just changed bands to 20m to have 14.150 USB pop up w everything off and went to Menu/Profiles/40m-20m CW Load - no change. Set everything back to my defaults, went to Menu/Profiles/40m-20m CW Save. Change to 30m & back to 20m - fine. Change to 30m again, back to 20m. SL A is fine, SL B appears also on 14.150 USB 2.7. Go to Menu/Profiles/40m-20m CW Load - again, no change. Appears either I'm not understanding how to use profiles, or they're not working the way they should.0
Ken, take a look at You Tube if not done that yet. Many very instructive videos about Flexradio. Just search for Flexradio and you get a ton of suggestions. This one is not to bad about Profiles specifically: https://www.youtube.com/watch?v=3s7UbKiqxAA
On Flexradio.com and Learning center you will find videos as well. I find a video much easier to follow than reading manuals
The combination reading the manual and watching a few videos is almost unbeatble. Link to Flex videos: https://www.flexradio.com/videos-flex-6000/ 0
- 375 Community Topics
- 105 SmartSDR+
- 427 SmartSDR for Mac
