Need the latest SmartSDR and Power Genius Software?
SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
I have heard bit and pieces of V3
I have heard that V3 will have remote operators to log on too my radio and operate it from a remote log on it. So i will to talk some of my friends that loves contesting but the money to build a good station. So now thinking of rules and regs I need to build for my contest station a little better.
Your thoughts
Jim
WU5E
Your thoughts
Jim
WU5E
- 65 Community Topics
- 1.9K New Ideas
- 117 The Flea Market
- 5.3K Software
- 4.9K SmartSDR for Windows
- 35 SmartSDR for Maestro and M models
- 84 SmartSDR for Mac
- 143 SmartSDR for iOS
- 149 SmartSDR CAT
- 66 DAX
- 278 SmartSDR API
- 7K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 553 Maestro
- 14 FlexControl
- 720 FLEX Series (Legacy) Radios
- 147 Power Genius Products
- 116 Power Genius XL Amplifier
- 10 Power Genius Utility
- 21 Tuner Genius
- 41 Shack Infrastructure
- 22 Networking
- 88 Remote Operation (SmartLink)
- 50 Contesting
- 125 Peripherals & Station Integration
- 61 Amateur Radio Interests
- 402 Third-Party Software
The new version 3 multiFlex software is perfect for your described scenario. You effectively can have two operators at the same or separate locations operating the same radio (only one can transmit at a time but all the slices and antenna ports can be shared as desired.)
Normal FCC rules apply for this type operation.
Here is an example of contest rules (CQ Worldwide DX Contest)
C. Multi-Operator Categories (all-band operation only): Any number of operators is allowed. QSO finding assistance is allowed. Only one transmitted signal per band is permitted at any time.
1. Single Transmitter (MULTI-ONE): Only one transmitted signal on one band permitted during any 10-minute period (run station/signal). Exception: One — and only one — other transmitted signal (multiplier station/signal) may be used during any 10-minute period, if — and only if — it is on a different band from the run transmitter and the station worked is a new multiplier. The run and multiplier transmitters are governed by independent 10-minute rules. Ten-minute periods begin with the first QSO on a band. The log must indicate which station/signal (run or multiplier) made each QSO. The multiplier station/signal may not call CQ (solicit contacts). Please be sure to read the Multi-Single FAQ section at <cqww.com/rules_faq.htm>.
a. High Power: Total output power must not exceed 1500 watts on any band at any time.
b. Low Power: Total output power must not exceed 100 watts on any band at any time.I'll be pleased to answer other questions about station configuration and hardware once you have a rough idea of the desired station capabilities. BTW, the PowerGenius XL is a perfect companion for this scenario.
Mack
W4AX
Alpha Team
As one person is looking to pounce on a contact, the other would transmit, switching between them.
Every Ham friend, you have given your Smartlink Login, can connect your F6. You can share your station since V2 with every worldwide !
Multi-single is best approached as shift work, not this sort of thing. At least IMHO.
For MS you need 2x TRX + 2x Ant + 2x PA = 2 separate stations [2 TX at same time]
What you wrote is SO2R [only 1 TX at one time]
This has been tested bye many of these contesters already....
Use cases that I have personally used:
1. Multi-single contesting as I described in my post above. This is a very valid and widely used contest mode. If you're a contester you've worked many teams using this mode. It's about skill.
2. The ability to share a slice(s) with another user while on a nationwide net. I talk with friends from TX, MN, IL, MS, GA, and TN every morning. By sharing slices among us we can hear what the other station is hearing without having to use one of the WebSDR resources.
3. I can be operating casually on 40M and one or more of my friends (each singly at a time) can connect to my radio and use my antenna farm and PGXL amp. Often my QTH can hear things that their antennas can't. For example, right now I'm using my 6700 and working satellites. The 6600 is connected and sitting idle. One of my friends could log in and make a contact.
There are many other possibilities waiting to be discovered. This is groundbreaking technology and the visionary hams will find many new uses.
Yes, a version 2.5 is planned and will be lingering bug fixes. There will not charge for this version if you have already purchased version 2.
Mack
W4AX
Alpha Team
That is exactly the same conclusion I have reached. 99% of my activity is DX. It might be fun to play with for a while but with my operating style I will be hard pressed to see $200 value in V3.
Keith - AC9S
KN7K
Heh, you love you some hype.
