LOST SOUND IN KE9NS POWERSDR
Don Hamrick
Don Hamrick Member
edited January 2019 in FLEX Series (Legacy) Radios
I finally got KE9NS PowerSDR up and running perfectly. On restart PowerSDR lost sound. I still have Windows10 sound for YouTube videos. What PowerSDR setting caused this loss of sound? Click the immage to enlarge it.
  • DH2ID
    DH2ID Member ✭✭✭
    edited January 2019
    Set the virtual cable to the settings I posted.
    You need only two cables.
  • Don Hamrick
    Don Hamrick Member
    edited January 2019
    Where did you post your virtual audio cable settings?
  • Gavin Badenhorst
    edited January 2019
    The default settings allow everything to work as it should. It is a plug and play system. I assume you are using the front phones jack for your audio. If so it should just work.
