LOST SOUND IN KE9NS POWERSDR
Don Hamrick
I finally got KE9NS PowerSDR up and running perfectly. On restart PowerSDR lost sound. I still have Windows10 sound for YouTube videos. What PowerSDR setting caused this loss of sound? Click the immage to enlarge it.
Set the virtual cable to the settings I posted.
You need only two cables.0 -
Where did you post your virtual audio cable settings?
The default settings allow everything to work as it should. It is a plug and play system. I assume you are using the front phones jack for your audio. If so it should just work.
- 684 The Flea Market
