SSDR Freezing
Bill English
Since the latest Win 10 update, I notice that my SSDR will occasionally freeze. The audio on the radio continues, but the software is frozen. The only fix I have found is to just wait, and within 15 seconds or so, it unlocks on its on.
I also noticed that on digital modes, I won't have any signal output at the beginning of transmissions from time to time. In a 15 second transmission I might get 5 seconds at the very end of the transmission. It does not do this every transmission, it's all occasional. I have ran this setup almost a year without any issue of this type. I really think it's related to that last update.
Thanks in advance.
Bill K4FX
Thanks in advance.
Bill K4FX
The symptom sounds like loss of ethernet connection. I became aware of the general problem when RF would occasionally get into my ethernet switch near the radio. Audio kept going and display froze.0
Hello,
I have the same phenomenon, with my new 6700, it's not him, Windows still plays tricks
73, on5po, Janny
version , HRD 6.5.0.187 seems to have solved wsjtx decoding problems, slowness, everything seems resolved
730 -
I think it is as simple as the connection, Although I have no issues anywhere else with the network. I have since purchased a 6600M and it does the same thing.
I have been trying to find the link to Tim's suggestions on the network settings. Could someone help me out?
Bill0 -
Bill, just out of curiosity, what's the spec of the computer you are using? Second, have you been trying to run Windows taskmanager to see status of the PC when running your applications?
Reason for asking is that just a while ago I was preparing an 3-4 year old PC with Windows 10 Pro to use in a demo of my Flexradio. After having installed SSDR, WSJT-X and some other stuff I had the taskmanager running and showing 100% processor usage. Taskmanager might give you a clue on status not only for your Cpu usage, but memory and network as well.
I realised that PC power might be a factor when we are running our SDR radios
It's an I5 3.2 Ghz, with 16GB Ram, 1TB SSD, I forget the video card, but it's midline, around 300 bucks, it's not the best but far from the worst.
Task manager does not show anything out of the ordinary. Only thing I see is a lot of dropped packets.
Bill1 -
Tnx Bill,
you should be in the clear then. The PC i was using was only 2.1 GHz and 8MB Ram. So you are good bit better in performance. Just wanted to make sure it wasn't as easy as that.
When it comes to the network and dropped packages then. Before I totally rebuilded my home network early 2018, new cabling, new switches, I had similar problems sometimes. Figured out that I had poor contact or similar with some of my old cables. With new cabling everything was OK. My experience is that it takes very little of bad connectors and/or connections to ruin our Flex experience.
Have you tried a simple thing as plug in and relase your cabling in/out of your switch/es, router etc a couple of times? I know it might sound ****, but a bad connection might not show just by looking at the connector. Don't ask how I know .. Lets say it's based on experience
Johan/SE3X
I re-plugged all the connectors, not many, the router is next to the radio, however, it no longer drops from full scale on the network indicator. Not losing packets either.
Something so simple.
Thanks for the help guys.
Bill K4FX1
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 190 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
