6700 front panel display
roger na4rr
I know that the front panel display is a wasted item but I did get use to seeing calibrate when initializing and my call sign when it was finally booted up. Mine has goon dead, Noting shows. The power button goes green and I hear the fans running so I know its on. Anyone else have this happen.? I havent taken it apart to look for a part number,. Dont even know if you can get to it, If someone has been there done that let me know, Thanks
Roger
NA4RR
Roger
NA4RR
Hello Roger,
My 6500 did the same but it hasn't affected the running of the rig. I must open it up sometime to see if I can replace it or if Flex would supply me one.
Bill - G4erv
My 6500 has just developed the same blank front panel display problem. Rig functionality appears unaffected - but I would prefer to get it back to normal.
Barry GM3YEH.
Roger, Bill and Barry,
Now there are 3 reports in this post, so it may be something more of us can expect to see eventually.
In addition to the startup messages, there are a few critical error messages displayed on the 6500, and 6700 front panel. Voltage error messages and the CPU and FPGA fan error messages are some examples. Mine is working fine but if it failed I'd also want to fix it.
I'd be interested in what you hear from FRS or others here about the part and if replacing the panel is a field serviceable item.
Al / NN4ZZ
al (at) nn4zz (dot) com
6700 & SSDR-W V 2.4.9
Win10
The front display is used for diognostics, when pushing the left and right arrows to enter codes.
I am wondering how difficult it would be to do a factory reset without having the count down dispayed.0 -
Hi Bill,
There were a lot of ideas on adding functionality to the front panel submitted over the years. Here is one of the idea posts from 5 years ago. There were a few others as well.
https://community.flexradio.com/flexradio/topics/front_panel_display_an_idea?topic-reply-list%5Bsett...
Initially FRS seemed to be considering them and other features for the display. For a few reasons I doubt they will implement any of them now or consider new ideas / features for the panel. ( I'm assuming the countdown change you mentioned would be a new feature....is that correct? )- The new models don't have a display
- the 6700 is the only model with the panel that is still in the current lineup
- it has been 5 years since these ideas were brought up and no enhancements have been made (except for the feature to display your call sign)
Al / NN4ZZ
Win10
What I mentioned about the the display being used for diagnostics is not a wish feature, it is used now for trouble shooting. There are combo arrow pushes to bring up different trouble shooting info on the dispay.
When we press the on button and the enter button the screen counts down for us to release the buttons to begin a factory reset.0 -
Hi Bill, Re: your comment. “I am wondering how difficult it would be, to do a factory reset without having the countdown displayed” It sounds like you were asking about a change / enhancement. Is that correct? Regards Al / NN4ZZ0
No, this is what the radio does now, the display counts down when you press power and enter at the same time, this is the startup for a factory reset.0
My 6500 front display is also a victim of the blank display. This must be a faulty component issue that inherent in this model since it is occurring on multiple boxes.
Anyone know what would be the repair bill for this issue? Any responses from FRS corporate/support?
It is a pity that Flex don't respond to this problem. It must be a faulty component as a lot of users have the same problem. If Flex would supply one, I would fit it myself.
Flex - please respond to this problem and help us out. If it is a standard component that is available from Mouser or similar, I would happily buy one and replace mine.
Bill - G4ERV
Hi Bill,
RE: "Flex - please respond to this problem and help us out. "
Flex doesn't appear to reliably respond to questions / problems here on the community like they used to in the past. If you open a "help desk" ticket they will respond but it is unlikely they will provide part numbers, etc for a "fix it in the field" repair. But you should be able to get a price and time frame for sending in the rig for repair.
My guess is that getting the part number would be a process similar to what happened with the fans. Someone ( a user) would need to open up the rig, remove the display and find a part from digikey, mouser, etc.
If you do open a ticket, please let us know what you find out. And of course if anyone opens the rig and figures out a part number that would be great.
Al / NN4ZZ
Win10
RE: front panel stopped working
Did anyone open a ticket on this issue?
Regards, Al / NN4ZZ
Got a reply from Tim. $65 for new display. $100 labor plus shipping.
roger
na4rr
I also have a problem with dead front display on my Flex 6700.
Anyone knows is it a systematic problem (design flaw, bad quality component) ?
Many thanks in advance,
Tom, 9A4T0 -
I sent my 6700 back for other reasons and just got it back. They of course reset everything. My display has FLEX-6700. Now I can not remember how to make it show NA4RR. I looked under radio setup. Then under Radio Identification Nickname I put NA4RR and under Callsign NA4rr. Still not in the display. I also rebooted the radio. Its no big deal but I liked having my call up there.
- 330 Community Topics
- 598 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 398 SmartSDR for Mac
- 261 SmartSDR for iOS
- 247 SmartSDR CAT
- 180 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 164 FLEX-8000 Signature Series
- 911 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 726 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 947 Third-Party Software
