QSK
Serge Mazza
Member ✭
hello, I can not uncheck the qsk in cw,
how should I proceed?
serge F6IPT
serge F6IPT
Serge,
Here is a portion of the SmartSDR User Manual. Change the CW Delay slider to change QSK characteristics.
Mack
W4AX
Alpha Team
If you want to turn QSK off, first turn on CWX, then select the Setup Tab, and you will see a toggle on the top of the panel to turn QSK on and off.
Chuck
Simply move the delay slider to a desired delay and you will then have semi break in. There is a known bug in SSDR. The QSK switching does not function as expected. You can search the community for details.0
Conditions must be really good. I'm 599 in Wisconsin.
- 390 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 58 Aurora
- 974 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
