Maestro
Jimmy Collis
Is it true that you have to plug the Maestro up to the 12v supply every 30 days or the internal clock will malfunction and you have to send back to Flex to reset does that mean you cant let set over 30 days with out charging ??????
Only with the “A” model Maestro which has the power button on the top0
Flex has a on-line doc, on how to open case and charge internal battery. No need to return to Flex.
Lew
Lewis so if I buy a new one not u have to keep charged or on older ones tnx0
That's what I understand.
When at home my Maestro AIs always using the dc supply, so never a problem. Also if using a dc battery when portable there is no problem. Gene, K1GD0
Tnx for info Gene0
Also do you know a link to buy battery for the maestro0
Check here: https://helpdesk.flexradio.com/hc/en-us/articles/210311883-Suggested-Battery-Packs-for-Maestro
I got the Mogix and it's great.
Tnx for the info0
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
