Maestro
Jimmy Collis
Is it true that you have to plug the Maestro up to the 12v supply every 30 days or the internal clock will malfunction and you have to send back to Flex to reset does that mean you cant let set over 30 days with out charging ??????
Only with the “A” model Maestro which has the power button on the top0
Flex has a on-line doc, on how to open case and charge internal battery. No need to return to Flex.
Lew
Lewis so if I buy a new one not u have to keep charged or on older ones tnx0
That's what I understand.
When at home my Maestro AIs always using the dc supply, so never a problem. Also if using a dc battery when portable there is no problem. Gene, K1GD0
Tnx for info Gene0
Also do you know a link to buy battery for the maestro0
Check here: https://helpdesk.flexradio.com/hc/en-us/articles/210311883-Suggested-Battery-Packs-for-Maestro
I got the Mogix and it's great.
Tnx for the info0
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
