My 6600m is doing a weird thing at start up.
My 6600m is doing a weird thing at start up. It will go straight to the display, then will go blank and show a message something about an ip address.  Once in a while it will show the picture of the 6600m and i touch run.    Any one know what is going on.  no problem at all with the radio.
Welcome!
  • Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator admin
    edited April 2019
    What does the message about the IP Address say?
  • Member ✭✭
    edited January 2019
    Client is connected to  ip address then it gives the ip address.  it does not stay there long enough for my old brain to get it wrote down.  will keep trying mike.
  • Member ✭✭
    edited January 2019
    192.168.0.2
    edited April 2019
    Hi
    You will need to take some time to explain further.   Is it just the IP address message you are worried about?
    Does the 6600M work like you expect it to?
    thanks
  • Member ✭✭
    edited January 2019
    Yes. Mike.  no problems with the 6600m.  Just wanted to know why it's doing that because it never did it before.  It's like it want to connect, but it's already connected.
