Cannot register with SmartLink 6500 new firmware
James Lee
James Lee Member ✭✭
updated firmware 6500, which has never had problems to date. When I click icon to open SDR  I get invitation to register with Smart Link. Pressing "register" button does nothing.
  • JohnSweeney
    JohnSweeney Member ✭✭
    edited August 2019
    Are you using Internet Explorer 10 on your computer? If so, please upgrade to IE11 and you will be able to register. Most web sites no longer accept IE10 due to security issues.
  • James Lee
    James Lee Member ✭✭
    edited January 2019
    Hi John:  thanks for the tip.  i do not use Internet Explorer on this new PC that I just bought for "shack use only".  My problem disappeared when I finally did something correctly (?) and registration suddenly took place and suddenly my screen lit up.  The 6500 is back on the air and just worked somebody on 40 CW, all seems dandy now except propagation of course lousy.
    Jim'
    NK7B
  • JohnSweeney
    edited August 2019
    Sorry - no easy software download to fix propagation!
  • James Lee
    James Lee Member ✭✭
    edited January 2019
    HA HA.
  • k3Tim
    k3Tim Member ✭✭✭
    edited May 2020
    Smart SDR version 5.0 will fix propogation in 2023 when it's released.
  • James Lee
    James Lee Member ✭✭
    edited January 2019
    I have now fallen from my chair laughing and broken left ankle.  My attorney will be contacting you,
    HI.
  • James Lee
    James Lee Member ✭✭
    Can anybody tell me what this alien signal is. Always present as shown here, wanders back and forth around 7183. Real pain because several nets use this freq. It is a whistling sound and like wind blowing. Cannot ameliorate with NR, bandpass changes, etc. It is very annoying and sometimes as strong as S7. Thanks.,
    Hi James, that is likely a switching power supply in your location, or perhaps at a neighbor's house. Try unplugging wall-warts, TV sets, laptop power supplies, etc to see if you can isolate the piece of equipment causing the issue. Note that simply turning things off usually has no effect, they need to be physically unplugged.
    Once you identify the culprit, ferrites on the power and other cabling might help, and might not. It depends on the mechanism that the RF is using to get into your radio. If it is direct radiation from the device, there is not usually much that you can do. If it is radiating from a power or other cable, mix 31 ferrite beads often help.
