USB Mic, remote problems
I recently purchased a new PC Laptop ( Windows 10 ) to run Smart SDR remote from the main station. I have no problems with CW, and digital modes. All works well. My problem is with SSB.
The problem is getting Mic audio output. Just for testing I purchased a Logitech USB H540 headset ( as I said just to see how I liked remote ssb). The LapTop detected the headset and installed it OK. I have no problems with receive audio from the Flex 6500. Went to the Sound setups, and found the headset, which was checked off and made sure that it was also the choice for recording. Made sure that the VOX on the Flex was on, and also made sure that the Mic was set for PC. No transmit. The Flex did not go to xmit.
Just for the heck of it I put the USB Logitech on my main computer in the shack which is a Mac Mini , and went over to my user page for DogPark SDR and tried SSB, and it worked fine. Just getting started with DogPark, and normally use BootCamp and Windows 10 for the Flex.
I assume that wireless Mics would set up the same as USB with just with the extra step of pairing with BT.
Thanks in advance. Lance L k4wh
Is the PC Audio button at the top right lit so you can turn it on?0
Yes0
This is what Bill is referencing:
This setting tells SmartSDR to look for the TX audio from the PC.
If you where also sending Data Audio from a program like WSJTx, you would make sure the DAX button is highlight.
You may want to also check page 77 of the SmartSDR manual (section 18) on how to us PC Audio as there is more information there that can help you out.
Thanks, Michael. That is what I had set up. I just printed out that part of the manual. It's pages 72 - 76 now, I think. Not using windows at all except for SmartSdr , all my real world stuff is Mac, am I maybe missing something in the Windows set up ?? or maybe the Logitech does not have enough output ?? Another thought, do I use the DAX TX choice, or select the Logitech option ??
Hi
Should you not be using DogParkSDR? https://dogparksoftware.com/dogparkSDR.html
It does really help when you provide the entire station setup.
VOX DOES not work when running remote PC audio with SmartSDR version 2.49
you have to use MOX or a CAT port PTT to get your MIC audio to the Radio.
Turn off your VOX and DAX and try the MOX button to see if you have audio.
73's
Bret
wx7y
Bret thank you. MIke, no. I switched over to Dog Park, just to try the headset mic out, and to see if USB did work. I prefer Mac OS for everything except ham radio. I find that Windows is a bit easier, for me. So my issue is abt using a LapTop as a remote.0
Bret, thanks again. I do have it working now, but .... I also have VOX working. Just clicked it on and its working with the USB mic from the Lenovo PC.
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
