Flex 6400/Maestro output to TV hookup
Joseph Hill
I would like to put my Maestro screen up on a 32" TV as well. What is the method to do this in terms of the setup on the 6400? Anybody know the output resolution of the 6400...4K? Thanks!
Hi
The only way to do this is with the 6400M model. It can't be done with the Maestro or a non M model unless you use SmartSDR on your computer and have it on an additional monitor.
The non-M models and the Maestro do not have any other video out options.
I would suggest that you download the 6400 manual from the Flexradio web site. It is all very clearly described in there. There is a download link at the top of the home page, or this link will get you directly to the download page:
https://www.flexradio.com/downloads/
GM Joeseph,,
I am making an assumption that you are talking about a Maestro or a 6400M/ Model Flex?
1: A maestro by itself is a standalone display/control unit and does not have the facilities to also be connected to an external display.
2: The same applies to a straight Model 6400 or 6600 radio (Non-M series) .
3: Only the 6400 or 6600M models are equipped with an external displayI port with 1920X1200 resolution that allows you to have both the front panel Maestro display and an external display at the same time.
Hope this helps
73 Larry k1UO
You guys are fast!! or I am a slow typist
there were no responses when I started typing.....
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
