Remote , Windows Laptop or Ipad ?
Ed Stallman
Question about using my Flex 6600 remotely . I would use remote maybe 6 to 8 times a year . I read an Ipad with a 10 to 12 inch monitor plus the ISO app works very well . Kind of pricey so maybe something used would do the job ? Can Teamviewer be used with an Ipad ? If I could log into my home computer , I could use my SS Amp .
How about a Windows Laptop , I don't own one but I know Teamviewer would work . Not sure how well tethering a laptop to a smartphone works ? I have Smartlink setup and have the green light here at the fixed station. The information I've not found is how to log into Smartlink using the Laptop while at Starbucks ? Do I load SSDR on the laptop ? Then connect to Smartlink , Should see my 6600 at my home ? Not having a laptop to test , I have to ask .
I prefer to use a laptop , I could use it for other things when not remote .
Thanks Ed N5DG
Thanks Ed N5DG
Personally, I have both. For me, I prefer the Windows interface, largely because I have other remote VPN connections that I need to make to control amplifier and antenna rotator.
I really like the iPad user experience. It's not so great on an iPhone (too small).
So for portable operation, my choice is Surface Pro, but both work well.0 -
I use my ipad my iPhone and my computer (Windows) for SmartSDR. I contrôl my power supply with One switch wifi and my amplifier with another.
Thanks Rick and Jean , If I buy a Laptop do I load SSDR onto the laptop ? Then to log into my 6600 , I log into smartlink ? If that's all their is to it sounds fairly easy
Thanks Ed N5DG0 -
if your radio is already open. the smartlink does not open the radio remotely. smartsdr V2 for remote0
Sorry , I don't understand , I'm setting at Starbucks and open the Laptop computer . How do I link to the 6600 at my house ?
Ed0 -
You put on you flexradio before go outside. Or you buy wifi switch for put on your flex with your phone0
you have more setup a this link,
https://community.flexradio.com/flexradio/topics/succesful_6000_power_on_standby_control_on_the_lan_...
Jean , thanks for the link . Turning on radio , power supply's , amps or turning rotor is easy enuf to do .. I do Not have a laptop to try to log into my Flex 6600 while at Starbucks . What Software do I need to install for the laptop ? would that be SSDR ? is this correct ? Do I open the laptop at Starbucks and load SSDR ? I guess if I had a Laptop , I could see if that worked
Ed0 -
Ed - I’m in Cypress, less than an hours drive. I’d be happy to take you on a demo tour if you’d like. Rick0
That is correct, if you have a 6600 then you already have a version 2 license.
Make sure before you leave the house you enable the 6600 on the SmartLink server, and open the ports on your router it tells you too when you register SmartLink (You have to be at the radio to hit the PTT, or CW Key on the radio it self) then you can login remotely with SmartLink / SmartSDR from about anywhere with a good network connection once you login to the SmartLink Remote device using the login information you provided when you registered the radio.
Sounds more complicated then it really is, here is a you-tube video
https://www.youtube.com/watch?v=kMbi3dAiMi0
73's
Bret
WX7Y
Rick , Jean and Bret Thanks all . Bret thanks for the description and youtube link . I have smartlink setup here at the house , tapped the paddle and have the green light . I'll shop around for a Laptop and build from that .
Ed 0 -
Ed, when you are shopping around for a laptop, I'd caution you not to get one of the cheap ones based on a slow processor. You don't need a gaming class laptop, but you will be running SSDR along with a bunch of sound processing, and perhaps digital modes and auxiliary tools. The graphics processing on cheap laptops is done by the CPU, and you can bog it down easily. I tried a cheap Acer, and it just did not do the job. I tried a still relatively inexpensive Lenovo with an i5 of some kind in it, and it did just fine. My opinion only, of course.0
Ted thanks, I was curious about that , I'll look around for something with an i5
Ed0 -
I use an old Dell Inspirion (N5110) with i5 CPU at 2.4Ghz with 6GB RAM and it works fine for connecting to my 6600M via SmartSDR and SmartLink. Nice 15.6 inch screen. Runs Win 10 Pro.0
- 112 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
