USB connector Flex 6400
Laurens PD9X
Hello all
In what way do you use the USB output of the Flex6x00? Ik want to try to control my UltraBeam with this. But I like to hear your experiences with what can be more connected to this.
I use my Flex remote over internet v2.49
Hi Laurens
This should help you out https://www.flexradio.com/downloads/usb-cable-interface-guide-pdf/
In RS232 mode, the radio sends band data in Kenwood format of either your active TX Slice or a specific antenna port.
Mike va3mw0 -
Laurens,
Here are two diagrams that show how I use my 6600 and 6700 USB connections to control literally everything.
Mack
W4AX
Alpha Team
This diagram is a bit outdated. The radio is now a 6600 and the amp is now a PGXL. The transverters have been moved to the 6700 for 160M - 23 cm.
I use one usb to control my amplifier band switching. I use another to control my remote coax switch band selections.0
- 637 The Flea Market
- 144 SmartSDR+
- 432 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 46 Aurora
- 958 Maestro
- 57 FlexControl
- 932 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
