Looking for Simple Wan Switch
Mike-VA3MW
I am trying to find a SIMPLE Wan Switch. Here are the requirements.
I've ruled out Digital IO Logger due to cost and no basic interface. In fact, I have 1 of the 8 port ones to sell in Canada if someone wants it.
Sonoff... That held some promise, but it would not connect to my WiFi network, it requires an App to control and turned out not to be basic plug and play.
This one hold promise: https://www.ebay.com/itm/Industrial-Ethernet-16-Channel-Output-TCP-IP-Internet-Web-Relay-Remote-Swit.... 16 Channels for $60.
This one https://www.ebay.com/itm/LAN-Ethernet-2-way-Relay-Board-Delay-Switch-TCP-UDP-Controller-Module-WEB-L..., has promise. I'm not so sure if there is an onboard web server. If anyone has played with it, I would like to know. For $4.59 and free shipping, I might order 1 or 2 to test with, but it might take up to March to receive.
Thoughts? Mike va3mw
- Simple
- Not WiFi - LAN connection
- Onboard Web server
- 2 or more dry contact relays
- runs on 12VDC
- Does NOT require an App on IOS to run.
What about a PDU; on/off 120v and 240v, 8 outlets each.0
Hi Danny
The PI is too complicated for some, otherwise I would recommend the RemotQTH Server solution I posted a bit earlier.
Thanks for your thoughts though.
These are the 2 solutions I have found so far from KMtronic and work very well.
2 relays: https://info.kmtronic.com/kmtronic-lan-ethernet-ip-2-channels-web-relay-board.html
And
8 relays: https://info.kmtronic.com/kmtronic-lan-ethernet-ip-8-channels-web-relay-board.html
I've used the 8 relay one for years and it will also accept commands from PSTRotators control pages.
It is about $75 shipped from Bulgaria. https://www.ebay.com/itm/KMTronic-LAN-Ethernet-IP-8-channels-Relay-board-WEB-BOX/281238587151?hash=i...
Mike va3mw
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
