WiFi vs Cat 5e / 6 Connectivity Maestro
Barry Young
When I connect my Maestro to my 6400 via WiFi, when I record my transmission, on playback it has a tendency to break up (choppiness). I haven't had any reports of choppiness, or my transmission breaking up during contacts. This is due to packets dropping etc. If I connected my Maestro directly to the router / Gigabyte hub, I assume this would go away??
My Maestro is approximately 15 feet from the the wireless router. It registers mostly good and excellent as far as the connection. I do see lost packets... I think that is typical for networks.
I think I am going to have to connect the Maestro via Cat 5 / directly to the hub / switch...
Thanks!
Thanks!
You are correct0
That is what I do and have had no problems. I have a 20ft. run from my modem to my 6500 and also to my Maestro. Have had no dropouts at all.0
.... but if you buy/use CAT cable, spent 5 cent more and take CAT 6 cable - it's the better one for Ham's and his RF :-)0
Hello give your maestro in your router priority for WiFi, many router can do that in the WiFi settings. That will fix it 73 Harald DJ4HW0
No matter how close you are to your access point, other signals in the area can interfere with your WiFi. It is always a good idea to do a WiFi survey of your area, then avoid the busy frequencies. Often in busy areas (in North America anyway), 2.4 G is very congested, and 5 G frequencies provide a much better opportunity to avoid competition. WiFi backs off when it detects other signals on a frequency it wants to use.
- 353 Community Topics
- 617 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 174 SmartSDR for Maestro and M models
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 23 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 285 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 758 Peripherals & Station Integration
- 978 Third-Party Software
