WSJT-X via Smartlink - Problem with DAX "modulation"
Adde Tjernberg
Hi All,
Running WSJT-X and FT-8 on my 6600 and it works great when I'm at my "Radio QTH". But when I try to do it remote, via Smartlink it does not work. Decoding signals works UFB. TX works but I can't get any "modulation" when transmitting. All DAX "buttons" are turned on, and it says "Streaming" in the DAX Control Panel.
Any ideas?
73 de Adde, SM0SHG
Any ideas?
73 de Adde, SM0SHG
if the computer your trying to use with the exact same setup as it does at home other then your using SmartLink, your firewall/router may not be set up to pass all the needed ports through the Internet to the radio.
Just a thought
Mine works fine here on my radio.
Bret
WX7Y
Problem solved... With some help from a fellow ham. The issue was that some the device names (soundcards) got **** up. Probably when updating Win 10.0
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
