WSJT-X via Smartlink - Problem with DAX "modulation"
Hi All,
Running WSJT-X and FT-8 on my 6600 and it works great when I'm at my "Radio QTH". But when I try to do it remote, via Smartlink it does not work. Decoding signals works UFB. TX works but I can't get any "modulation" when transmitting. All DAX "buttons" are turned on, and it says "Streaming" in the DAX Control Panel.
Any ideas?
73 de Adde, SM0SHG
  • WX7Y
    WX7Y ✭✭✭✭
    if the computer your trying to use with the exact same setup as it does at home other then your using SmartLink, your firewall/router may not be set up to pass all the needed ports through the Internet to the radio.
    Just a thought
    Mine works fine here on my radio.
    Bret
    WX7Y
  • Adde Tjernberg
    edited December 2018
    Problem solved... With some help from a fellow ham. The issue was that some the device names (soundcards) got **** up. Probably when updating Win 10.
