The screen is not fully visible on SDR-1000 v. 2.44
werner51
I have in use PowerSDR software 2.44
The screen resolution of my old laptop is 1680x1050.
I can´t see the fully left and rigt "knobs", also the upper and lower knobs are not fully visible.
I have tried some other screen resolutions without success.
The SDR hardware in use is an old LIMA -SDR.
Does anyone have a "good" hint to solve this?
Check your font size, set to normal and see if it makes a difference0
TNX for the answer- this was the reason.
hpy new year and merry xmas.
regards Werner
Usually this is the “DPI” setting in the display properties. Should be set to normal or smallest, logout or reboot for it to take effect. Dudley WA5QPZ0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
