Dax Drivers
Ed Stallman
Ed Stallman Member ✭✭
I found Tim's "How to Manually Re-Install DAX DRIVERS
This looks old to me as tim refers to SSDR 1.6.12 .. I tried this 3 times with very little luck . yes I changed the 1.6.12. to 2.3.9 . The bad DAX Drivers are giving me images on CWSkimmer and I think FT8 .
I've placed a help ticket but Tim can/t duplicate it  . Now waiting to hear from Eric
Sending a screenshot of skimmer
How can I repair the DAX Drivers?  Flex seems very busy image
  • Ed Stallman
    edited December 2018
    Not a good screen shot , I will try again
  • Ed Stallman
    OK better image
    Ed
  • k3Tim
    k3Tim Member ✭✭✭
    edited May 2020
    Can you send an image of the DaX panel, sound (playback) panel and FT8 spectrum tuned to an active band with signals?
    I have a suspicion Flex is busy for a (rumored) software release.  :-)
    edited April 2019
    Quick question.
    Are you using SliceMaster or SDRBridge?
  • Ed Stallman
    edited April 2019
    Michael , using Slicemaster
  • Ed Stallman
    I'll make a screenshot and send
    OK, that helps.  Does it behave the same way if you use SDRBridge?  What we want to do is make sure that review all the pieces of the puzzle.
  • Ed Stallman
    Mitchael , Eric gave me a hand via team viewer giving SDRBridge a try . SDRBridge is working with no images . I'll have to get used to the colors of the CW traces .
    Ed
  • Ed Stallman
    Tim , Eric at Flex looked at my DAX drivers and said they were all there
    Ed
