Has anyone successfully used the SIIG FireWire Express Card (NN-EC2022-S1) with the 3000 and a Win X
Jim Johnson
Just looking for a possible solution for a Win XP Laptop with no FireWire to use with a Flex 3000.
Jim
I'd keep looking and find a firewire express card with a TI (Texas Instruments) chipset, the card you're asking about has a VIA VT6315 chipset. It might work for you, but the VIA chipsets are not 100% compatible with the PowerSDR firewire driver.For real-time discussions
User created documentation.
Volunteer!!73, Jay - NO5J
Thanks Jay! Based on what I have seen so far, I don't have much hope to find anything!
I have been looking at a DELL laptop that include a Firewire port, but unfortunately not much details on the unit. Asking $169 for the laptop, guess I have throwed a lot more money for a lot less reasons... hi
https://www.pcliquidations.com/p39258-dell-latitude-e5500-15#
Anyone got one of these?
Jim/KC4HW
Here are some spec I found at cnet.com
- Interfaces
4 x USB 2.0 4 pin USB Type A
1 x display / video - VGA - 15 pin HD D-Sub (HD-15)
1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x audio - line-out/headphones - mini-phone stereo 3.5 mm
1 x microphone - input - mini-phone 3.5 mm
1 x IEEE 1394 (FireWire) 4 pin FireWire
1 x display / video - S-video output
1 x docking / port replicator
Jim/KC4HW
0 - Interfaces
Jim
It's not like the VIA chipsets were guaranteed not to work, it's just that the TI chipsets always seemed to work. The issues with the VIA chipsets were mostly about poor performance, leading to audio drop outs, etc.
Does it have to be a laptop?For real-time discussions
If you've been shopping for these, you've probably already seem this one, more expensive, but it's TI, it will work.
https://www.neweggbusiness.com/product/product.aspx?item=9b-39-158-012
Thanks again Jay.
Well I am going to use a desktop from home with a PCI-E card. But I also have a small RV and was looking to use a laptop that would store away/travel easy. Planning a 5+ week RV trip now and there will be another 4 or 5+ weeks of different RVing activities in 2019.
At 70 years, I have accumulated three laptops (VISTA, XP & XP Pro) that are in very serviceable condition, but just don't have purpose. The XP Pro, Toshiba (~2004 vintage) does not have PC ExpressCard but instead a PCMCIA slot, but I did check and it does have a single 1394 Net Adapter, TI OHCI IEEE 1394 4-pin connector built in. So when I get the "new to me" Flex 3000 I will try it out to see if it will work. If not I did find this
https://www.newegg.com/Product/Product.aspx?Item=N82E16815283035&ignorebbr=1&nm_mc=KNC-Googl... that possibly might also work if I need a plan B...
Probably more than you wanted to know about all of this but I do appreciate your help.
C U around the Ham Radio Campus!
Jim/KC4HW
Jim
Sounds like a plan to me Try that option out before, buying any pigs in pokes.
- 632 The Flea Market
- 127 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
