External audio amp for line out
Craig Williams
Most Hams have a ton of speakers lying around. I was looking for a little 12V audio amplifier to use with the Flex line output. After the 4th try I found one that sounds good and doesn't have RF on it when I transmit and it is only $15.28!
https://www.ebay.com/itm/12V-Mini-2-Channel-Hi-Fi-Stereo-Audio-Amplifier-Amp-Car-Motorcycle-Speaker-...
Great price but I wonder how much distortion percentage is being introduced?
per ebay sellers data
5. Frequency Response: 20Hz to 20KHz
6. Distortion: <0.05%
7. SNR: >97dB
paul k3sf
I'd like to believe that, but considering the distortion specifications on brand name A/V amplifiers costing hundreds of dollars, such as Pioneer, Kenwood, Sony, etc have distortion specifications in the 0.08 to 0.09% THD range, I have my doubts.
Most peoples audio is so distorted anyway I don't know if a super specifications audio amp would do you any good. I have a good set of speakers/amp on my PC. Rock and role sounds great on them. Most Hams' transmissions not so much.1
I run my 6300 on remote, i.e. Remote in SSDR, and feed the computer's audio output to an old Yamaha amplifier (I use Tape Input 1) and from there to a pair of JBL Monitor One speakers - the sound is great. I spend much more time listening than I do operating.
I use it all the time unless I want to actually TX, in which case I use a Plantronics Blackwire headset which has good audio as well. I find the Plantronics earphones good enough to listen to music. Having said that I am 72 and my ears are not what they used to be!!
Tim
What is this Rock and Role???0
Rock and Roll with role play.0
I figured as much...0
I'm curious if anyone has tried the Heil Parametric Receive Audio System on their Flex?
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
