Flex 6600m ATU
Jimmy Collis
Is there any way to disable the ATU being I have ATU built into my amp I can't find anyway in menus to disable I cut off manually on front of radio but every time I change frequency or change bands it comes back on
2
Yes, mine is always BYP for the same reason. TX control window, right side.
Thanks Steven i went to the window on the pc screen i was looking for it on the radio not connected to the pc working fine bussiness now thanks again for the info
73 es gud dxing0 -
Steven, push the Mic-gain button and disable ATU MEM. The internal tuner will stay off now.
Correct. Turn off ATU Memory0
Thanks...
[{"insert":"The ATU on my 6600m , running version 3.3.33.10471, tunes the antenna on port 1 but does not reach on tune on antenna port 2 (even if you connect the same antenna). I have opened a ticket but was wondering if there is a quick answer / resolution here. I would appreciate any help.\nThanks\n\nWZ2J\nVin\n \n"}]0
You have made the antenna on port 2 the transmitting antenna?
- 389 Community Topics
- 53 Aurora
- 970 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
