Noisy CW an Maestro
I am using Flex6600 with Maestro (software 2.4.9).
The CW signals on the headphones, via LINE OUT and PWR SPKR are slightly noisy, as 600 Hz tones are noise modulated.
Can I hear the same signal through DAX on the PC, this noise is not audible.
Is that the hardware of the Maestro or can be improved with the software?
I have the same issue on my Maestro on cw. I've just cranked the AGCT down for a solution. Probably just network background noise.0
It could be the result of a ground loop issue too. Single point grounding all the equipment including PC's might fix it. But that may not be possible with the Maestro so look everywhere else.
For real-time discussions
User created documentation.
Volunteer!!73, Jay - NO5J
I've found that the backlight for the controls(MOX,TUNE,ATU etc.) from the Maestro is introducing noise into the cw audio chain. If you go to the menu and reduce to minimum or turn off the backlight it seems to cure it.1
Addendum.....This is not the same as the distorted audio when listening to cw on phones.0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
