CW Skimmer and SDR Bridge
W2ECK
I have CW Skimmer 2.1 & SDR-Bridge 1.6.4 installed and running. Using SSDR v2.4.9. CW Skimmer is showing signals and call signs, so it seems that the setup following NN4ZZ's Quick Start Guide went OK. Except---- the CAT function does not seems to work. The frequency in the CW Skimmer freq window does not patch the freq in my slice A, nor does it follow freq changes in SSDR or if I click on a signal in Skimmer it does not follow. I tried restarting Skimmer and SDR Bridge in "shaking" the panadapter but no change. Any suggestions
Paul
w2eck
Paul
w2eck
Hi Paul,
Take a look at the telnet settings troubleshooting notes on pages 5 & 12 in the guide.
If that all looks good, you can contract Ed ( SDR-Bridge) from his web page.
http://www.qrv.com/contact.html
He is also on the community but may not see your post.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
I have that problem with my 6700. To fix it I just change the band on the slice for a minute and change it back. Then the freq in Skimmer matches the Slice and will change as the slice changes.
Al & Pat - thanks for the suggestions. I got it to work. Not sure exactly what fixed it but could be just restarting the programs involved a few times. Al - the guide is very well done.
Paul
Hi Paul,
Glad you got it working. If it happens again and you can reproduce the scenario or fix let me know and I'll add it to the guide.
Generally the SSDR -> SDR-Bridge -> CW Skimmer setup is reliable but anytime you have multiple programs there is more chance for some hiccups. I've been using it for years now and no problems but I usually just have one instance of skimmer running and only operate CW so my setup is static.
The Windows10 updates can add to the issues as well.
Al / NN4ZZ
6700 & SSDR-W V 2.4.9
Win10
Al - understand - thanks for the additional information
Paul0 -
Paul, I have had much better luck using Slice-Master to open/setup and synch CWskimmer.
https://github.com/K1DBO/slice-master-6000
73, Dennis, k0eoo
- 378 Community Topics
- 118 SmartSDR+
- 193 DAX
- 38 Aurora
- 257 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
