I have a 6300 and will be using a Drake L7 do I need the ARB-704 and what pnp cable is used?
Don Stefanik
Drake L-7 hooked up to a 6300. Do I need the ARB-704 and what cable do I get?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Don
It would be good for you to actually take a voltmeter and measure the PTT keying voltage on the L7, or even check to see what it is in the manual. I wasn't able to find it in the manual.
Power up the Amp. No need for the radio to be hooked up at all.
Take a voltmeter and measure the voltage on the Amp key line. I think it is about 28V based on Googling around.
Now, put the meter in current mode and use both leads to short out the keying line and see what sort of current it draws. It is likely around 100ma or so.
If both numbers are less than what the radio can support, then you need a keying buffer. Here is a good circuit. http://www.ab4oj.com/dl/keyinterface.pdf
If you do need an interface, I have an excess ARB 704. Just let me know. 730
Why risk it? Just get the 704
What pnp cable?0
Plug ‘n play ?0
Highly recommend these 3-500z amps have High voltage that can destroy switching circuits in flex and other solid state rigs0
The 704 uses "rca" type cables and if I remember right it comes with a couple. I also believe the "L7" uses rca type but I and sure it is in the manual or an online manual...73's0
Another issue is whether you intend to use high speed CW. A relay is too slow in switching for full QSK etc so beware that the circuit that Michael pointed you to, might not suit. I use a solid state switch because the speed is so much quicker than a relay.
Like many who have answered, I would not take the risk of damaging your Flex by trying direct switching.0 -
Don,
I highly recommend the W7RY QSK board for the Drake L7. Not only does it provide a soft keying circuit (safe for keying by any modern radio) it also gives you nearly silent T/R switching. Nice for CW or SSB VOX use.
Note: It's not a kit - you have to round up the parts (including a vacuum relay) and modify the L7 to install it, so if you are uncomfortable with equipment modifications then it might be better to simply buy a keying interface. But a QSK-modded L7 is a really sweet amplifier.
Doug K4DSP
Ok thanks everyone. When I had my TS-590 and a AL811 I had the ARB-704 but I had to have a special PNP cable to operate the 704. RCA cable to the amp.
I have not been using a ARB-704 with my current AL80B and 6300 setup.
Also thanks KC7ES, but with the postal strike here in Canada shipping is a no go. I will just order one from DX Engineering which uses FedX to Canada and it's by far the least expensive way for me to order stuff. I usually get it in 3 working days.1
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
