When DAX is enabled, then VOX does not work from microphone
AB4EJ
I like to use SSTV, and interleave conversation with sending images. Recently, a problem has arisen: when DAX is enabled, then VOX does not work with the microphone. This is something new; in the past I was able to use DAX and VOX concurrently; now I have to manually switch DAX on and off when sending an image. Is this a "feature" or a bug, or simply a wrong setting somewhere?
came with the latest update. Flex is aware of it and will be fixed hopefully next firmware update.
This appears to be the same issue I reported in https://community.flexradio.com/flexradio/topics/switching-between-digital-audio-source-and-voice-au... At least for me, the work around this weekend for SS Phone will be to roll back to SSDR 2.3.9.
Tim K9WX
You can connect a footswitch to PTT jack on back of radio. That will enable you MIC input without needing to switch DAX on and off.0
I guess that's what I will do also, as I am planning to work SS and using a switch for this is just too much to do in the heat of battle, at least for me.
With this bug I lost time setting N1MM+ voice keying and it is very inconvenient to use a footswitch. I loved the VOX only and it does not stop the N1MM+ voice keying, I have to press ESC on the keyboard to stop the N1MM+ voice keying, press the footswitch.... very inconvenient.
Hope Flex will fix that.0
- 633 The Flea Market
- 129 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
