Help with SmartSDR software for use on a MAC
Vicki
I have a new Flex 6600 radio (traded in my 6500 and Maestro) and am interested in running this on my MAC computer (not my iPad or phone at this time). Is there a Smart SDR software for the MAC yet? I read a few posts on Parallels. If I purchase this software what version would be best, Lite from Apple store, regular or Pro from Amazon? Would this allow me to then operate the radio from my MAC computer? I also plan to run MACLoggerDX, WSTJ, JT bridge and LOTW. By the way I am a low tech computer user so please reply using non high tech instructions as I really want to get on the air using my MAC. Many thanks for any and all help, 73, N6KLS, Vicki
Hi Vicki,
You can run the native Mac client dogparkSDR - https://www.dogparksoftware.com/dogparkSDR.html,
or you can run SmartSDR under Windows emulation (i.e. Parallels) on the Mac.
MacLoggerDX will connect directly to your Flex over your LAN.
73 de VE3VRW Don Agro3 -
If you want to run SSDR on the physical platform of your Mac, you will need to use either BootCamp, or Parallels to run a copy of Windows, since for some reason, FlexRadio Systems won't port to MacOS.
My setup is as follows:
I use Bootcamp because it has direct hardware access and is a bit more efficient than running a virtual machine as you would using Parallels.
I use Windows 7 because Windows 10 is a horrible OS. If you are used to MacOS, you expect the software to run after updates. Not so with Windows 10. My Windows 10 machine sometimes has problems after an update.
Anyhow, Parallels is a viable choice too - I think most people run that. Windows 10? Let's just say that my W7 in Bootcamp has 100 percent uptime.
The downside of Bootcamp is that you have to boot into it. Not difficult, but some people don't like that. Performance versus convenience, I suppose.
There are MacOS options as well. DogPark is a really nice application that works well. I also run that on my Mac.
There is also talk about iOS applications running on the latest MacOS update, so you might even be able to use the iOS version. I don't know anything other than the talk about it.
Hope this helps0 -
I run DogparkSDR and also run Windows 10 using VMware Fusion. Fusion is cheaper than Parallels and you can run it on multiple Macs and don't have to buy a new version each year.
Burch
Me Too.
I do the same
this configuration is better than bootcamp because you can run native mac apps for wsjtx, mldx, jtbridge, which you can not do using bootcamp.
and
you can chose to either run ssdr under windows or dpsdr under macos
best of both worlds
Paul K3SF
On a slightly different note, I suggest you also invest in Loopback, and install xDax and xCat. That will allow you to also run any digital apps you'd like, with ease.4
yes...i totally agree...best set of s/w for digital work on the mac.
so is there a You-tube tutorial for DogPark that get into the nitty gritty for those of us that just don't have the time to poke around and see what happens.
73's
Bret
WX7Y
A lot depends on the software you need to use. I use N1MM a lot, and there is no native Mac Application that does what it does. Regardless, if you are wanting to run SSDR as Vicki says whe wants to do, you can run a VM on the Mac, or if you don't want the performance penalty of the VM's, Bootcamp0
Not sure on the Youtube but you can download DogparkSDR and run it for free for up to 15 minutes at a time.
I find that running SmartSDR on virtual machine is the same as running it on Bootcamp. If you want a Windows machine to run SSDR buy one. The Parallel folks did such a good job over the years with Parallels that using it is transparent. On the plus side is you can transfer file between MAC and Windows, can't do that with Bootcamp.0
You don't have to buy a new version of Parallels every year.0
Thumbs up on that.0
Me three.0
on the dpsdr webpage there are links to various youtube videos.
https://dogparksoftware.com/dogparkSDR.html
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
