Running PowerSDR on Microsoft Surface Pro ?
Is anyone running PowerSDR on a recent (2018) Microsoft Surface Pro Tablet ?  If so how is that working for you.  I am considering one of the Intel i5-7300U based ones with a 13" screen and 8 GB of RAM, running WIN10. It won't be my primary computer for controlling my Flex-1500 but it would be nice if I could use it with the rig while travelling instead of bringing my heavy Acer Quad-Core Laptop along.
Cheers
Michael VE3WMB
  • JohnSweeney
    JohnSweeney Member ✭✭
    edited August 2019
    I have almost identical SurfacePro and it works fine.  If you need a travel setup, you can also use an iPad using SmartSDR for IOS.
  • Michael VE3WMB
    edited November 2018
    Thanks John.  Just to clarify I want to run PowerSDR not SmartSDR as it is for a Flex-1500.
    From what I have read, these Surface Pros run real WIN10 so it should work.  I currently have an aging MacBook (2009) that has an Intel Core Duo in it and I have it setup to dual boot WIN7. It will work to run PowerSDR and I can even do CW at speeds less than 30WPM with little latency, but I think that this laptop is at about the bottom end of the suitable hardware range for running PowerSDR.  The Surface Pros are a bit pricey but I am hoping that since they are a Microsoft product that they do a good job of running WIN10.
    Cheers
    Michael VE3WMB
  • JohnSweeney
    edited August 2019
    Sorry, I read your note too fast.  I do not use PowerSDR.  Win10 works great on the SurfacePro.
    Good luck!   K9EL/VA3CDX
  • David Pearson
    David Pearson Member ✭✭
    I will be setting my Surface Pro 3 up in the next week or so.  I do no expect any issues with the Surface.
    I will be using my setup with my RV.
  • Mike  W1BFA in Maine
    Mike W1BFA in Maine Member ✭✭
    edited June 2020
    Will the Surface use FireWire? I’m getting close to firing up my 5000 for the winter and need to set up another pc. Mike in Maine
  • Jim Bryce W5HFS
    Jim Bryce W5HFS Member ✭✭
    The Flex 1500 with Power SDR works fine on my Surface Pro 1 and also my Surface Pro 3. it's a great combination for portability.
