Running PowerSDR on Microsoft Surface Pro ?
Michael VE3WMB
Is anyone running PowerSDR on a recent (2018) Microsoft Surface Pro Tablet ? If so how is that working for you. I am considering one of the Intel i5-7300U based ones with a 13" screen and 8 GB of RAM, running WIN10. It won't be my primary computer for controlling my Flex-1500 but it would be nice if I could use it with the rig while travelling instead of bringing my heavy Acer Quad-Core Laptop along.
Cheers
Michael VE3WMB
Cheers
Michael VE3WMB
I have almost identical SurfacePro and it works fine. If you need a travel setup, you can also use an iPad using SmartSDR for IOS.
Thanks John. Just to clarify I want to run PowerSDR not SmartSDR as it is for a Flex-1500.
From what I have read, these Surface Pros run real WIN10 so it should work. I currently have an aging MacBook (2009) that has an Intel Core Duo in it and I have it setup to dual boot WIN7. It will work to run PowerSDR and I can even do CW at speeds less than 30WPM with little latency, but I think that this laptop is at about the bottom end of the suitable hardware range for running PowerSDR. The Surface Pros are a bit pricey but I am hoping that since they are a Microsoft product that they do a good job of running WIN10.
Cheers
Michael VE3WMB0 -
Sorry, I read your note too fast. I do not use PowerSDR. Win10 works great on the SurfacePro.
Good luck! K9EL/VA3CDX
I will be setting my Surface Pro 3 up in the next week or so. I do no expect any issues with the Surface.
I will be using my setup with my RV.
Will the Surface use FireWire? I’m getting close to firing up my 5000 for the winter and need to set up another pc. Mike in Maine0
The Flex 1500 with Power SDR works fine on my Surface Pro 1 and also my Surface Pro 3. it's a great combination for portability.
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
