wsjt setup
DonE
I get a Hamlib error when i test CAT what have i got set up wrong. In screen wsjt under the radio tab it will not let me input anything on the serial port or baud rate and nothing below. I am following Tim's " configuring wsjt-x and Smartsdr for windows
Check out this thread https://community.flexradio.com/flexradio/topics/i-am-trying-to-get-my-new-6600-working-with-wsjt-x-rx-works-cat-doest?topic-reply-list[settings][filter_by]=all While it is for an older version WSJT-X, the setup is the same. Use TCP instead of serial. Also use WSJT-X 1.9.1 until 2.0 is released. Dave wo2x0
David i did everything i think i get receive but i see no transmit gain . when i tune in wsjt it does not show in the 6400 power out , what am i missing?0
Does it key the radio?
Make sure you use DigiU and in the Phone panel on right side make sure DAX is enabled. Also in DAX control panel make sure TX Stream is enabled.
Are you running Windows 10? You might suffer from corrupted DAX drivers. Search on here for a post from Neal Campbell on how to straighten that out.
it does not key the 6400, in the dax control panel TX is blue but never turn to red when i tune, how do you transmit ?0
Dave it does key the radio .0
Did you follow the screenshots in the link I sent? Are you using WSJT-X 1.9.1? Also does WSJt-X show radio frequency.? Make sure you choose CAT and Fake It0
Hi,
Here is my setup for WSJT. My TX button in DAX does not
turn blue when I transmit. All that shows is it is
streaming the audio. Call CQ. Try to transmit and if you
see the red line showing output level in the DAX TX. Go
into transmit by hitting the MOX button on the radio or
in the SmartSDR panel. If you then are putting out RF,
it means only the program is not keying the radio.
Below are my screens, your port numbers might be different,
but one should be your PTT port. You would find the port
numbers in your control panel.
My ports are COM 4 and COM 5. Com 5 in cat panel is set up
as the PTT port. Again your port numbers could be different.
73, Jim N9VC
Dave and Jim found my problem i had the audio output set wrong . thanks for your help0
Excellent! Dave wo2x0
Dave i know this sounds dumb but how do i key the 6400 in ft8 is it from wsjt screen?0
I suggest you review this page, including how to make your first contacr. This covers everything you need to know. https://physics.princeton.edu/pulsar/k1jt/wsjtx-doc/wsjtx-main-1.9.1.html Make sure your PC time is accurate. There are a few free programs that can keep the PC time accurate. I use a commercial package called Present Tense. Dave wo2x0
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
