Windows 10 1809
Jim Gilliam
Before installing 1809, I completely removed SmartSDR per Tim's instructions and loaded in 2.49. Everything worked perfectly. This has been my 11th uninstall/install.
Jim, K6QE
Hi Jim, you beat me to posting this.
If you don't do the uninstall of SDR, the DAX drivers are going to be messed up once again. Remember to remove everything including the DAX and CAT drivers. The good news is that I was able to recover without having to rename all the DAX device drivers as in the past. After the October Windows 10 update messed up the DAX drivers, I uninstalled all SmartSDR versions from the computer, including all the drivers. Then did a cold reboot. Installed SDR again and just like magic, it all played perfectly. But it is much better to uninstall SDR before the update. Yes, I know, one day I will stop being so trust worthy and follow the good advice.0 -
I let Windows install the 1809 update w/o doing anything to SDR.
In fact, I have never removed SDR before a Windows update.
Everything went well and all is working normally.
Tom W3FRG
Windows 1809 has been pulled from the update list due to problems especially deletion of files for some users. If you have not installed yet, DONT.1
And currently you can't install it. It's been removed. So going forward you won't need to any take steps to block it.
For real-time discussions
User created documentation.
Volunteer!!73, Jay - NO5J
Woops?0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 62 Aurora
- 974 Maestro
- 950 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 145 Amateur Radio Interests
