Losing first CW character when beginning xmit
sky
I am losing the first character of my CW transmission. SmartSDR (v 2.4.9) is in CW mode, I am using an electronic keyer plugged into the 6600 KEY rear input, transmit delay in SmartSDR radio setup (transmit tab) has delays all set to ZERO.
I had understood that in CW mode, the SmartSDR ignores the TX delay setting and heads direct to RF instantly but my first character gets lost in the slight delay when I first sent my first character (The first letter 'C' gets lost when keying my CQ).
Any suggestions? Thanks.
Sky,
Do you use an amp? A TX delay may be needed with an amp.0 -
Understood but I am not using an amp. I want NO delay.
Even with an amp, it should not truncate the front edge of a CW character or string. If it does, then it is no longer a QSK radio!0
Does it do that with the internal keyer of the 6600? Is the internal keyer disabled when using the external keyer.
This sounds similar to a problem I reported here several months ago. See https://community.flexradio.com/flexradio/topics/missing-first-element-in-sidetone
In my case, the first element was missing but only in the sidetone, not the transmitted signal. Several others responded to my post indicating that they have noticed the same behavior. I had hoped this would be fixed in 2.4.9 but I still think it is an issue.
Tim K9WX
Tim: Tnx fer the reply. I can easily hear that my first CW character is not being transmitted and see the same on the waterfall (monitor). My electronic keyer is provided the side tone accurately.
I have the Breakin button illuminated.
Interestingly, the problem was present up to yesterday but not today. I just made a CW contact and there was no loss of the first character. Everything operated instantaneously as it should. No changes or adjustments were made. I may have a moody SmartSDR program installed.
The transmitter delay has returned again!
- 113 SmartSDR+
- 920 Genius Products
